Best Bang for the Buck V6
tireman
atlanta
What is the best horse power improvement you can do to the V6? Or should I leave things as they are? Thanks.
either way you wont get much from them separately so just do them all, eventually.
the supercharger is set up for the V8 so good luck doing that with the V6
I didn't say supercharging i was saying Turbocharging, but about V6 surpercharged you couls put a vortech surpercharger you have enough room under V6 hood
I was told you would have to do remote turbo if you went down that route.
But for that you are going to spend a few thousand dollars, so start with CAI and XCal
If all you want is the most go for the money then NOS is your answer. I really liked adding the magnaflow exhaust, it really seemed to wake up the 4k and up range. I bet a lot could be had from tuning also. If you have the automatic and want better launches then do a stall converter.
Torrie has told me he has tunes for the V6's also.
nitrous is by far best bang for the buck. you can put it together for a few hundred bucks and add 100whp. cant beat it. but you probably wont do it
