joegr
Why is it that on my 2000 Mazda Ranger I can get a code to tell me exactly which cylinder is misfiring but on my 2005 Lincoln LS I just get a broad statement? lol
If a coil fails altogether, then the LS can accurately detect that. However, the particular failure mode for the LS coils is that they start to arc inside. This makes them marginal such that they often fire the plug, but sometimes don't. That is much harder to accurately detect.
Do you know how cylinder miss detection works? The PCM measures the speed, acceleration (rate of speed change), and position of the crankshaft constantly. It knows that each time a cylinder fires, the crankshaft should accelerate ever so slightly then slow back down. If it doesn't, then it flags that as a miss. It then tries to figure out which cylinder it was based on where the crankshaft was. This is all actually very hard to do, especially when the coil is marginal and the cylinder might fire late.
