invisiblem0nst3r
got a big leak in mine today do i hope.... the leak is coming from the middle of the engine guy i got it from last week said it had a "little" leak well its a big leak now has anyone had this problem before?
will you ?? maybe i will get everyone elses attention on my 5th post and ill keep changing the title to itt
That sounds like the oil filter adapter gasket. do a search on "oil filter adapter gasket"
and you should find a lot of information, its an inexpensive part, and if your handy enough to change the oil, you should be able to do it.
Is this saying you hope you have an oil leak? Most people hope that they don't.got a big leak in mine today do i hope....
If the leak is in the middle of your engine thats a good thing, oil lubricates many of your essential parts in the motor. I would not consider it a leak, it is normal to have a 5 qt leak in the middle your motor. If you have a leak on your oil dipstick that means its all good, no oil leak on dipstick very bad.the leak is coming from the middle of the engine
There must be a reason for this, you never take a word from a stranger about a car before inspecting it yourself, did you pop the hood, look under the car. He may have at one point had a car that leaked like a little school girls eye after sliding her knee on a the pavement while trying to catch a frog that was hopping away when a rock caught the side of her shoe and made her fall due to the uneven weight on her ankle. So to him this might have been a minor leak.guy i got it from last week said it had a "little" leak well its a big leak now has anyone had this problem before?
whoah i think this is the nicest you guys have been to a newb!
You were impatient to buy the car and now you're impatient to fix a big oil leak for buying a car you impatiently purchased...maybe it's time to be patient and stop blaming people for your impatient mistakes
check oil filter adapter gasket....gasket is $20 from the dealership, remove power steering pump remove housing clean throughly install new gasket torque
