Tru-Trac Diff w/FRPP 4.10's
DLF
Forked River
Tru-Trac Diff w/FRPP 4.10's **SOLD**
If there's any interest in this, please let me know.
I have all the parts in my garage to put this together, I just haven't done it yet. I was planning to replace the True-Trac/4.56 pumpkin in my Cobra when I install the aftercooled Vortech and forged short block that I have, but that project has been delayed a bit.
$800 in new parts:
New 912A562 True-Trac differential (no clutches to wear out).
New FRPP 4.10 gear set.
New ARP ring gear bolts.
All new Timken bearings and races, and OEM Ford seals in a used Cobra carrier housing (I have all the correct tools to install the races and seals properly).
New ARP Carrier studs and nuts.
This is not my first differential build, I have the same setup in all three of my cars, just with different gear sets.
$900 + shipping.
$1,000 installed (Forked River, NJ).
It'll take me a day or so to put it together (I may have to hunt up a pinion flange, as my Cobra driveshaft uses the larger 1350 flange).
This would also be a good opportunity to upgrade to a LPW differential cover and ARP stainless steel cover bolts (2 packs required) as pictured below (installed in my LSC).
It will all work in an LS. Just need 1st gen LS axle shafts, a custom front brace, and a custom drive shaft.
I'll defer to your experience, but I will only install it in a Mark VIII. ;)
