So we get about 11" of snow here in Dallas(first time ive ever driven in this much snow) & as i was driving the traction control light, anti lock & check traction control all came on! what the hell happend?
No...all lights are still on
then you have killed or a dirty wheel sensor or a failed VSS sensor.
Something is pissing off your TC/ABS system.
Do you have CEL "check engine light"?
on my mark, the TC light comes on whenever the TC engages
its a little light indicating "you spun" and TC had to assist
Dunno if the LS is the same.
There is no VSS sensor on the LS.
might not be a typical VSS in the tail shaft.. but
there IS/HAS to be a "vehicle speed sensor" SOMEWHERE otherwise the speedometer wouldn't work.
then it uses the abs sensors to determine VSS, that makes the ABS sensors are used for VSS...
and your post, probably points right TO the issue.
ABS sensors probably have crap/metal on them, corrupting the Vehicle speed data
