amplifier
2002_lincolnLS
Custom User Title
canton
i was wondering ig this would work i imagine it would but... ok so my idea is to run another bass amp off the existing one. it would be relatively small just to run a 10 inch sub i have. i would run new power and :q:q:q:q just split the rcas if thats what the stocker uses. anyways if someones tried it let me know if not ill try it later
If you do it correctly, it will work. However, the stock sub amp does not use RCAs. You would have to splice into the wiring. The only trick will be getting the ground returns right.
hmm being an electrical engineer i can handle that lol but yeah figured it would it just eliminates the need for more rcas or low pass filters
ok thats cool i figure anything to avoid pulling up carpet and :q:q:q:q is good
