Mechanicboy
How do I find out which one of the 2331 manuals that were made is mine? I searched on google and could only find the factory output production number, not the number referenced for the 5 speeds?
I don't think you will find your number of the 2,331 produced between 2000 and 2002 other than your 2001 was in the middle.
The "production sequence numbers" aren't sequential, they're randomly assigned, so it won't even tell you where it was in the assembly sequence. You can't really tell much from it, because the car with the next lower number (if it's even assigned) might be a Town Car and the LS ahead of it on the assembly line might have had a higher number.The last 6 numbers in your VIN is the production sequence number. However, I don't think that will not tell you which number your's is, as far as which v6 manual. It will just tell you number in the assembly line.
Yeah, you would think a "Production Sequence Number" would be, well, sequential, but apparently the logic train didn't quite make it to the station on that one...Thanks. I was guessing as to what it exactly meant. But " production sequence" would lead one to believe it was the number on the assembly line.
The Ford guy might just pull a number out of his ass. How will you know? :shifty:![]()
Some people were able to get some pretty descriptive break downs of the 98 Mark VIII build info back in the day... it's worth a shot.
I think I have what you want, the list of all the LS Manuals built, sorted by VIN with build dates and much more info. Give me your email and I will send it to you.
