lostsoul77
I got a 4 wheel alignment on the LS yesterday at NTB. All was within spec (not far off before) except the for the right front. The camber measured -0.7 on the right front before and after the alignment while the left front measured 0.0. They say that the camber is not adjustable on this car and it was probably negative from hitting a pothole. Is this true? After leaving the shop and testing the new tires and alignment, if I let go of the wheel, the car will roll straight and then gradually start drifting/wandering to the right. Is this due to the negative camber which they say can't be adjusted and is there a way to correct this? I'm supposed to take it back to them today after work as they claim that the problem is one of 2 things:
1. They didn't put enough air in the right tire
2. It wasn't aligned correctly
