Help....abs sensor/snap on or bolt on
LongIslandLSE
long island
Called max to order the drivers front abs sensor, he needs to know if it is a snap on or bolt on. If anyone knows it would be great, i called some dealers and they could not tell me. the wire was held on by a small C clip but im not sure what else comes with the sensor.
year 2002 lse
snap on IIRC. I just changed my pass side wheel bearing, and there weren't any bolts. The other side just snaps in, just behind the wheel well liner.
This was on my 2000 V8 Sport.
Hey Long Island
Get me your complete vn number and Ill try to run it through ford and get the p/n of the one installed new from the factory.
max
yeah im a legit type of guy. will be doing this sunday morning, will let you know how easy it is. replacing both abs sensor and clockspring.
there are two type of wheel bearing one with Torx screw and other with C clip I think LS with advance trac have Wheel bearing with bolt and and Stock LS Traction Controle have C-Clip Wheel bearing
Well that was pretty damn easy, the longest part of the project was driving to the autoparts store to buy a gear puller. Abs sensor was cake and it fixed the problem. Now I also have an airbag, radio controls and a horn, inspection Friday.
good luck, i could get you one for 150 if you want? haha
