DTC: c1095, c1286 codes information
themissinglink
wisconsin
I get the advance trac message, traction light and my abs light won't go out. I have an abs code reader and regular obdII reader.
I get the codes:
C1095 ABS hydraulic pump motor circuit failure
C1286 Booster mechanical failure
Does this for sure mean the problem is not a speed or abs sensor, something nice and easy?
P0401 EGR Flow Insufficient Detected
P1504 Idle Air Control Circuit Malfunction
P1565 Speed Control Command Switch Out of Range High
and another one for cyl 7 misfire
If you live in the La crosse, W.I. area I will check your codes for free!
I get the codes:
im gonna go with the sensors, that usually is what happens, but you never know!
I get the codes:
Yes, this means it is the ABS module itself, not a sensor.
codes
Now I am getting just these codes. I don't really know alot about this scanner.
The engine has stopped missing since I put fuel system cleaner in it and I no longer get the misfire code.
p401 exhaust gas recirculation flow insufficient detected
p420 catalyst system efficiency below threshold bank 1
p430 catalyst system efficiency below threshold bank 2
p1504 idle air control circuit
If anyone is interested in the full live data report, let me know how you get it off of a blue point ya3160. I can't find a way to just tranfer all the data, it won't even let me save the date from live data. Just a little information is saved when you save a report.
live data information
Does this information make anyone think something is wrong with the car?
calculated load value: 58.82
engine coolent temp: 206.6
short term fuel trim-bank 1 32.81
long term fuel trim-bank 1 -10.16
short term fuel trim-bank2 32.03
long term fuel trim-bank2 -14.06
engine rpm 693.75
vehicle speed sensor 0mph
iginition timing advance cylinder #1 9.50
intake air temp: *f 125.60
airflow rate from mass air flow sensor lb/min .56
absolute throttle position %18.43
bank 1- sensor 1 v .43
bank 1 -sensor 1 %32.81
bank 1- sensor 2 v.78
bank 2-sensor 1 v .34
bank 2-sensor 1 %32.81
bank 2-sensor 2 v .83
