oldhead
Seen a show on speedtv the other day. Compared the MKS(turbo) against the BMW 5, Jag and Meredes, The tesing was done my Automoblie Magazine. see the video
www.6versus8.com
www.6versus8.com
The front grill needs to look way less like a 15yo kid with braces.Good video...glad Lincoln is competing but the mks needs to look less Pontiac-ish
lol reminds be of.....The front grill needs to look way less like a 15yo kid with braces.
shoulda put the ecoboost in the MKZ...
that makes me proud of lincoln and ford, finally something from this company that can firmly stick it up the ass of mercedes and all the snooty :q:q:q:qs that drive them![]()
Does anyone know if a test run Linconln LS vs. Lincoln MKS?
And I think the SHO is on par with the MKS in terms of Luxuriousness
The MKS has more weight and less power at sea level than almost all of the other cars it was raced against. It was the 2nd heaviest and lowest powered of the group.
Ecoboost MKS is pretty fast for its size.
http://www.roadandtrack.com/article.asp?section_id=10&article_id=8255
more weight and less power... and more than likely less handling
do you know how much of a handicap 12,000ft is comparing N/A to F/I?
maybe I just hang out at the dragstrip too much lol
just to give you a little idea....
14.7PSI is atmospheric pressure... 12PSI is the stock ecoboost 3.5L PSI
14.7 + 12 = 26.7PSI
14.7PSI is atmospheric pressure at sea level... every 2,000ft you go is 1.1PSI dropped
so @ 12,000 ft atmospheric pressure is roughly 8.7PSI... add corrected atmopheric pressure to your stock PSI
8.7 + 12 = 20.7PSI
now you have to calculate the percentage of air loss you lose compared to sea level... so divide
20.7/26.7 = 78%, so you would have 22% less pressure through an turbocharged engine running 12PSI
now... compare what the loss would be with a N/A car of the same caliber, so instead of boost pressure we have to divide atmospheric pressure
8.7/14.7 = 59%, so 41% less pressure through the N/A engine
now that we have our figures let's calculate to make the MKS a naturally aspirated 350BHP like the rest...
Ecoboost 350BHP @ 12,000ft = 273BHP 3.5L TT DOHC V6
if the car was naturally aspirated and making the same power?
it would only make 207BHP... making it's WHP less than a 99-04 V6 mustang considering it has to go through an AWD drivetrain
like I said, the comparison is so biased and the handicap is so large... you might as well have put phelps in a swimming match against a dead dog
