Electrical help needed with interior lights.
starfox86
Cape Coral
After taking the cluster out, taking the chime mechanism off, and reinstalling the cluster, I now have no window, lock, shifter, or cluster lights (I can't tell how fast I am going at night). . I do however, have the digital milage, digital info, open door safety lights(bottom of door), turn signal, e brake, airbag, cruise control, and seatbelt lights. The radio and A/C display lights work fine as well.
-I know there are no fuses burnt out because I've checked them about 20 times.
-The interior dim switch is working fine with the lights that are on.
-I doubt if all the bulbs are burnt out because that would be wayy to many to burn out at once! ( i will be checking this tonight)
-Does anyone have any suggestions??
hmm, maybe a harness not fully plugged in?
I JUST FIXED IT!!! omg im soo excited, I have been without these lights for about 4 months!
Here is what I did: I took the abs light out that I knew was working and then I switched it with one of the speedo lights that wasnt working. I plugged the cluster back in and everything worked! :wrench
lol, good job, if it worked before, you just have to go back and check everything , good job!
