Doctor_Wu
Oh ye masters of the LS... I seek your wisdom again.  I have read several threads on the issue of A/C problems and see many posts on the DCCV along with the DATC... more on that in a moment.
I have a 2000 LS V6...
I have cold air coming out of the drivers side and hot air out of the passenger side.
To be specific the A/C is blowing 50 degree air out of the far left (driver side vent) vent
57 degree air out of the middle left vent
67 degree air out of the middle right vent
69 degree air out of the far right (passenger side vent)
All fuses are good. (Not sure about relays... do they fail 1/2 way?)
The DCCV has been replaced in the last 12 months to fix a problem with the heater last winter.
I have used vice grips to clamp off and block any water flow from both sides of the DCCV to the heater core
I do get a fault code of 12 42 on the DATC self test and that reputed to be a failure on the recirculate air door. In turn, I have closed the recirculate air door so no outside air can enter the car... and it's still cold on the left and warm on the right.
The AC compressor is running and does not cycle off.
In other threads I have read several accounts of such failures, and several "solutions" mentioned.
Saw one person claim to have resolved this via turning the fan speed to max, then cycling the temp all the way to 90, then back down to 60, tried that and it did nothing.
Have seen a couple of people mention getting a new DACT unit, even buying one from a junk yard... and that fixing it.
Have seen at least one person mention the interior temp sensor (some reports indicate there are 4 sensors total)...
Have also seen a mention of a loose pressure switch causing problems.
Is there a definitive fix for this failure... or a way to escalate the trouble shooting...?
Any advice or accounts of similar failures and subsequent repairs would be appreciated.
TIA,
DW
TIA,
DW
