air suspension problems??
trevor_reyell
amsterdam
this is going to sound really weird it does to me... but my front right side air bag seems to have a leak but holds air sometimes and sometimes not?? baffeled yet....? then when its parked it can be low on the right front then with the key not in it and the doors locked it pumps itself up?? how can this be.... then problem number three it could be pumped up and holding air fine till someone opens the passenger side door....???? please im open for suggestions or answers need help i have a nice 93 mark with a healthy motor and would like to keep it around... thanks....
T
T
You need new front bags.
Its not weird...its a common problem.
Do a search on this forum....... http://www.lincolnvscadillac.com/forumdisplay.php?f=6
also post your questions about your Mark there.
T
Sounds to me that you have a bad solenoid or relay on the right front. Have you checked it for leaks when it was up? If not , the next time its up turn off the air ride switch and jack it up, then spray the air bag with a mixture of water and dish soap, Dawn or Palmolive is what I use, if its leaking you will see bubbles as they form.
