Lincoln Jealous
- Joined
- Aug 8, 2009
- Messages
- 3,118
- Reaction score
- 17
on the factory brake caliper, when replacing back on the brake pads the brake pads became snug like the 2 pistons were applying pressure, then about 5 minutes later, the outer pad became lose again, and only 1 piston was applying pressure. is this a sign the caliper is bad, and needs to be replaced? all my other calipers are applying the regular pressure on the pads, where they are not movable. also when checking the pads on the "bad caliper" i noticed a uneven wear on the pad - like one piston is working harder then the other one.. thanks
