Low Brake Fluid Light
StuartJ745
Philadelphia
The warning system on my ’01 LS displays “low brake fluid” with the brake warning light coming on. The fluid is at the correct level and the pads are fairly new. This happens about once a month. It will clear after a day of driving. Any clues??
Have you tried unplugging the float switch at the reservoir when the light is on? The light should go out. If it doesn't, then you have a shorted wire somewhere. If it does, then you know that the float switch is defective.
hello LVC, i just read this because it just had this happen too... levels are fine, but brake light came on for a sec and turned off, and computer read low brake fluid, what should i look for? thanks
Did you try this yet? :confused:
well the light only flashes for like 1 sec, then it goes away, came back like every 5 minutes for 3 times, i checked the resivor wires, maybe they were alittle loose, but i dont know how to check this unless the light was solid, when i press on the computer status, it says brake level is ok, so i dont know, but i will have to drive it again to see if the light comes on
Unplug the sensor on top of the brake fluid reservoir, and drive for a day or two. If the light still flashes, then you have a wiring or cluster problem. If it doesn't then you can assume that it is the brake fluid level float sensor and replace it.
i read this online
"Then I moved to brake fluid sensor, which gave alert even when container was full of fluid. The sensor looks unserviceable, but actually the rivets are screws. So if you grind slots to them, you can screw them out. The float appeared to be normal cork, which propably has soaked so much fluid during 40 years that it did not float any more. And then comes the joyful part: where can you get a new cork? From wine bottle of course! And a bottle without cork goes bad quickly, so of course you have to drink it! Best repair ever! Restoring a car is fun! New cork in place, everything back together and works perfect."
i read this online
Don't use a cork. You will have to replace the sensor assembly if it is the problem. (Or, just leave it unplugged and check you brake fluid level often.)
haha, well this time it came on solid and i unplugged the wire and it turned off, so i believe it would be the sensor, has anyone replaced one before, im not sure if this is a autostore part? could it also be the cap? does pressure build up there too?
Looks like you get a free sensor with every reservoir..sorry.
P/n xw4z-2k478-aa retail $52.80 and LVC is $39.60.
M
No, the reservoir does not pressurize. I don't see any way that the cap could be your problem.
