Rich88LSC
That looks great. I like the look of just the turn signal tinted .
The grille and lenses look good on that silver man!
Do you think it would look good on a 2nd gen lens? I really wanted clear but this is probably cheaper than custom lenses!
Great project! How long did the entire process take from start to finish?
Also, is there a problem with using the regular turn signal bulbs?
Just might do this tonight or tomorrow....
So what if I tape off the inside of the lens and then dye the outside clear part of the entire housing? Even for the taillights, like open them up and tape off the inside as to not restrict any light output, but the outside would still be dyed?
Just finished with this mod! Looks great, cant wait to see how it looks during the day. Thanks again JWerner.
What do you mean it would be minimal? Like it wouldn't tint them enough to be worth it?
Layers for darker look cannot be acheived? You said you didn't put much dye in. What about adding more? I wonder how it would hold up if exposed to the elements like that?
From the way yours turned out all glossy and nice looking, I wouldn't see how doing it on the outside of taillights would be a problem, as long as you clean/wax regularly like I do already.
This just seems way too easy and not common? Is it just like an undiscovered way of tinting or something?
Those fogs would look great tinted out LSBlack00! What kind of wheels are those?
The lens. Take off the fog light and put it in the dye.
he'd have to put the whole assembly in which shouldn't be a problem. just put the lens face down and don't let any of the dye in the assembly. taking the fog lights off is not difficult at all. don't make them too dark though
