ford dealer down the street from me wants $193 for a cobra one. they said its a day out.
why do you resist the advice people here give you.
You'd rather pay MUCH more for a local compressor than to order one from MAX?
Max supports this community and we should all return the favor by supporting MAX.
his prices BEAT your local dealer, and the shipping cost will be offset by the lack of Sales Tax you wont be paying to Max.
Almost everyone pointed AT your alternator, you kept saying "the alternator tests good".
you should be a little more receptive to those that are merely trying to help you.
No $hit.That is because they are having it overnighted from MAX to them.
Bypass the middle-man and call Max and save yourself money
i also rater would not buy an alternator unless i know that its the problem and i don't want to wait for a week either. i would rater just pay straight wholesale in town and have it now. napa has cobra ones in stock here, so i will pick up one from them if needed, and it has a 3 year warrenty, compared to a 1 year from ford.
i tend to trust a several thousand dollar machine and a guy that has been in the auto industry 20 years and little more than people that haven't even see what the car is doing. when i see the alt is putting out voltage, and it also tests good on the machine, i am not going to just blindly spend 150-200 bucks just to do it.
everyone says it might be a diode, but can anyone tell me how i can test that?
No $hit.![]()
It gets frustrating seeing posts where one asks for advice and the OP does THE EXACT OPPOSITE of what was suggested....ok I will shut up now, I feel better..
ALTERNATOR
DO YOU THINK HE HEARD ME?
I went through three napa before I bought the ford
everyone says its the alt, but i took it off the car, went and had it tested and it passed every test on the machine. i haven't bought anything yet, and i will not buy anything untill i know what the problem is. blindly changing parts is no way to try and fix a car. it could be the alternator, in fact it probally is based on everyone's experience, but untill it fails any test i give it, i am not going to buy one. i just don't have the money right now to buy an alternator if mine is fine. if someone can't suggest any more tests i can do on the alternator, please let me know.
just drove it around with everything i can turn on turned on to try and re-create the light show it did last week. it didn't do that, but it did do something else, i have a CEL on from when i removed the EGR system. when i took off the CEL turned off and the car started bucking really bad, stoped after a few seconds, CEL turned back on, and all was well again.
came back home, the lowest the battery would go was 12.2 volts with wipers, a/c, rear defrost, lights, and radio turned on. ran the codes again, the only code there was 327 from having no EGR.
everyone says its the alt, but i took it off the car, went and had it tested and it passed every test on the machine..
That listen option should include an open handed slap function would you like me to call the patent people now.![]()
you need to do a bounce test
take it back off the car, go to the auto parts store and bounce it across the counter.
For the record, I said "battery" then alternator..
In the order of expense.
If you dont have 300.00 for potential repairs for your car then you.
1. have the wrong car
2. have the wrong job
