spark plugs 2000 caravan
take off the alternator bracket and pull the alt forward and then you can get to that one and the others should also be easy
as they said, from underneath is easiest. done a few now. on a hoist is easier than on the ground. then you can get your arms up there just right. a couple of short wobble extensions and a universal make it easier. good luck.
wobble extensions????
I tried from up top i decided to not to peruse any further after i realized that i need to take the windshield wiper drain tray out to get the plenum out.
I'll try again later
wobbles have rounded edges that allow a little offset. kinda like a universal, but not the range.
like ball end hex keys.
