De-marko
Like the title says I have this code popping up. I have new autolite platinum spark plugs and new coil packs. I pulled the new coil off on cylinder 6 and examined it pretty good.
Everything is connected and I used electronic connector spray on the plug-in to the coil and then disconnected the battery for a couple hours. After putting the car back together I drove about 40 miles before it popped up again. I pulled the coil and plug to see if everything was ok on the spark plug and it is. I used an old coil I know is good, reset the system and that code is still popping up along with a blinking CEL on accelaration.
Any ideas? Fuel injector maybe?
The only other code, (P0174) I have now is saying I have a vacuum leak, but I haven't had time to search that out yet.
