Rifleman@LaymansPC.com
I recently bought a 2004 Lincoln LS V6 and am in love with the car, but have a few issues I'd like advise on. I'm beginning to think everything might be somehow related.
I recently had a code P2106 that pointed to the Throttle Position Sensor which I changed (the plastic housing of the original was actually melting) and it was also recommended to have the system PCM reprogrammed to correct the TPS issue (which also corrected a hard upshift issue).
Since getting the car I have had to replace the fuse that controls the traction control and D5>D4 (overdrive off) functions several times and finally ended up installing a 10A fuse (stock is 5A) in an attempt to get the device drawing too much power to fail so it can be tracked down and have had no issues with it since.
Now I am having a P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage code. I have cleared the code twice, the car operates as it should until the first time I shut it off and restart it again, the engine light reappears with this code. Although the car still operates flawlessly, I do not want to run it with the light showing.
#1 (Please correct me if I am wrong) I assume the code is meaning to replace the MAPS?
#2 Is there any way of testing this circuit and knowing the ranges that would be "acceptable"?
#3 What are your ideas on any or all of these issues being related? If so where should I start in diagnosis and where could I find voltage and amperage specs on the different components?
#4 Do any of you think the issue could be caused from a failing battery (OE from '04). A few months ago I ran the battery low during cold weather and it almost would not start the car until turning off all accessories and waiting a few minutes for the battery to recover after reducing load. In reading through this FINE, FINE forum I've seen it mentioned on several occasions that a low battery can create many "weird issues".
Any thoughts are welcome and appriciated. Any solutions, I owe ya my life as I ABSOLUTELY LOVE this car on the twisties here in north-central West Virignia.
