the DCCV short term while a replacement is on order. Its 96 degrees out and my DCCV took a crap. Once i get the new one i will have it installed asap, but for now is there a way to plug/block/cutoff the coolant hose that goes to the DCCV itself. Mine is unfortunately stuck in the fry your nuts off position and i figured even though the valve is stuck i could somehow stop the flow of coolant to the DCCV valve itself. Make sense? Any sort of plug that could be inserted and secured on the hose supplying the hot coolant?
