Will you be swapping the snowflakes with drag tires on at the track? If so I would get the MT ET Streets, they hook better than the MT drag radials or the Toyo drag radials... and I would think the 4.56's and the 4000 stall would be perfect. Although you will have to shift into 4th gear at around 115-118mph and that's shifting at 6800-7000... just something to think about cause you don't want to be flooring it in overdrive...
