Stangman
Project car a.d.d.
Figured I'd try and see if anyone else is having this problem on their first gen with OBD1
When my car is cold, as in, just started, let it idle for a few, then put it in gear and go, I can "try" to stand on it and it will buck, and hessitate, and pop and crack as it get's higher in the RPM's in first...
I let off and it will shift into second, and all seems normal unless I were to stand on it again.
Now once it gets warmed up, I can stand on it and it will shift, may hessiate a little bit or pop and crack but it will not buck and basically say "EFF YOU"
But now if I were cruising it on the highway and stand in it, it will upshift, and start to go, but then once again it will pop, crack and just feel like all the power is not there. Every soo often I can actually feel the car "open up". But of course within seconds it's acting up and I cant feel the true power of the car.
Now, Before you start telling me check this and check that, and replace this and replace that...
I have replaced the spark plugs with some good ones from NGK, I have MSD wires, new coil packs, new fuel filter, I have seafoamed the car 3 times. cleaned the MAF and the T/B... I have also tested the fuel pressure and replaced the o2 sensors. I am at a loss. I have no idea what this things deal is....
My car would be absolutely nasty wild if it would just show it's true nature and not act up...
Please help.
thank you.
Please help.
thank you.
