What to check/replace before putting engine in my '02 LS V8
FALECF4
Plymouth
As many of you know I am putting a used engine in my '02 LS V8. My car has 94k on it and I will be putting in an engine from an '01 LS V8 with 108k.:shifty: Now after I do this I don't think I will want to be having to do anything to this engine for a while. What things should I check and/or change while the engine is out before I put it into my car? I have the plugs, coils, and gaskets which are new from my engine and they will put into the other engine. Should take maybe an hour being out of the car!:D
I was thinking the thermostat for good measure, but I'm not sure what else to do. I was hoping some of the guys who have been with this engine for a while could point the way. What are common repairs at this mileage? I will be checking all of the hoses for wear or cracking. Would it be worth my while to basically do a simple rebuild? Fresh bearings, piston rings, and gaskets or would there be a lot more involved to that process?
Thanks for any info. This should all be happening at the end of April or beginning of May. I am dropping the engine and transmission together to hopefully make this all a little easier. I will do what I can to make a thorough write-up of the whole precess too.
Water pump for sure. Maybe the DCCV if it was acting up. If you had the rattling sway bar bushings, this would be a good time to replace those with energy suspension pieces. Just my .02 ;) Good luck with the project.
How much is a water pump new? Or maybe I could just keep the old one around, but that's mean I'd be changing it in car later. DCCV was always fine for me so lets hope that stays good. Sway bar bushings are crap! Those will be changed. Off hand does anyone know what the bushing kit runs?
Got a price quote for the water pump from the dealer for $122. How much is the DVVC? I also need help with the energy suspension bushings for the sway bar. What size do I need and about how much do they cost? Any one who has done the bushings, did you also upgrade to the endlink bushings?
