I have a 2002 LS V8 with about 98k miles and this weekend I am finally going to be changing my COP's, plugs and VCG's.  I don't think this job has ever been done on this car.  I was originally going to have the work done but from reading the forums it seems like a job that I can do myself on the V8 and save a ton of money.  I already have my new plugs and I am ordering a set of coils from alanisdeals on ebay.  From what I've read nobody has had an issue with coils from this seller.  I am looking for part number DG-515 correct?  Does anyone know a good place from which to order the valve cover gaskets and the other gaskets that I will need?  I read on one of the threads that you can get an entire sets for $35 or even if it was $35 per side but I haven't been able to find that thread again.
Any tips I need for this job other than what is posted in the tech articles? I need to be careful when removing the connectors from the coils so that I don't bust off the tabs. I am not sure if I have oil in by the plugs but I am replacing everything anyway because I figure my car will need it eventually with this many miles. In the tech articles it says to use dielectric compound and some silicone brake caliper grease. Dielectric for the electrical connector to the coils and the the grease is so they slide on the plugs easier? Obviously I want to keep any dirt out of the valvetrain but if there is oil in by the plugs do I want to try to soak that up with a paper towel or just pull the plugs and let it drain into the cylinder?
Well thanks ahead of time for any help. I'll make sure to take pics of everything too. About how long is this job? I am mechanically inclined so that should help.
