2002WRXSTi
So typical shudder and slipping was all my trans did. Plus when I went to put it into gear it would take it's own sweet time. Then when I would come to a stop I had to wait a second to keep from doing a neutral drop
Since I hit the big 200 mark I figured it would be better to service the trans rather than just replace it as I thought it was shot. Brief history, got the car @133k and do oil changes but was told the trans had been converted to synthetic ATF. I never thought anything about it sept for putting in Lucas every time it was low.
Well 70 some off thousand miles later and probably 6 or 7 Lucas trans fix it's I did a trans service. The ATF was a sort of Brownish red, dunno if that was from being burnt or more the color of the Lucas trans fix. Anyway after doing it about 20 miles later all the shudder stopped and it go's right into gear right away! Shift nice and smooth and almost all if good now. Well except for the drive shaft rumble that has become fierce over 70
Didn't do it before as I put in a 93' solid shaft, so I searched these forums but I still can't seem to find anything to look at to try to fix it
