Super Coupe Front Suspension Support Brace install
davidm
Broken Arrow
Installed the Front Suspension Support Braces from Super Coupe.
Easy to install, with drilling required for the front points.
Handling seems more solid, but not by a huge amount. My Strut bushings are fairly new also, along with sway bar end links. Had the 4 wheel alignment done after they were installed.
Hopefully the alignment will hold longer and maybe reduce wear on the front strut bushings with the support braces installed.
David M.
I had those on my 97 tbird plus everything else that kenny brown made for the tbirds and it handled like it was on rails. Hope you like yours as much as I liked mine.
PS: Fix that leak that you got going on there slim. LOL
i got both sets of braces to install in my car, just havent gotten around to it lol........
fix the oil leak :p
That is from the water and power steering pumps leaking. Both replaced along with the HPressure hose.
Valve cover gaskets are leaking now, drivers side is beyond my mechanical ability.
Checking shops for prices.
David M
David M
whats with the driver cover? i had mine off and i dont remeber doing anything other than prying the engine towards the pass side with a bar to get it out???
am i forgetting how hard it was to remove or something?
dont pry the engine lol jack up the transmission from the drivers side, theres enough play to get enough room to get the valve cover out........once youve pulled all the other stuff off of course :D , its time consuming, but not hard to do.........
