Tire Problem 255/35/20
Don Guille
San Jose
Hey Guys, I Just Got Some New tires On The Ls.
the size is 255/35/20 and They Scrubb On Jumps And Ramps.
Do Any of you had or have the same problem? What Can i do to stop the scrubbing. I Already added the Blocks in the spring and i'm still having the problem. PLease let me know what i can do!
Thanks!!!
Just roll the fenders. You got the wrong size tires. Sometimes in order to make things work you have to sacrifice.
You live in San Jose, weather aint so bad so I would maybe even remove the liners if thats whats rubbing. Then take out those 4x4 blocks.
"Have you taken your car over any sweet jumps?"
1: What does scrubb mean? Is it anything like rub?
2: I believe any sized tires/wheels will "scrubb" if you "jump" your car.
3: Were you using the "ramps" for those "jumps?"
Like was said before, it sounds like you've got too little offset on the wheels and quite possibly the wrong sized tire for the wheel you have on now.
Mark
Yes Scrubb is Rubbing,
And No i havent taken it on Jumps, Just Wile Drving on the freeway theirs some crazy parts were my car goes up and down then thats when i hear the Rubbing. I Check the fenders and i believe its the only place were it rubs.
As JWerner2 i will roll my fenders, hopefully that solves my issue.
I would at least look into a different size tire. You got the wheels now and no one ( except LsUNV2:D ) likes to HAVE to buy more wheels. Im guessing the width is 8.5 like most 20's so that tire size is not good unless you do have a high offset. That and pulling the liners, like I said if you want to do some dramatic changes you have to make sacrifice sometimes.
