My car dash makes what sounds like rubbing creaking noises (ee ee ur ur) after I turn it off once it's warmed up.
If I turn the car back on the noise goes away.
In the past the car made similar noises and got down to being a gallon+ short of coolant at which point it overheated and went into safe mode.
I only drove it a few blocks in safe mode and had it towed to my mechanic.
I think it was low on coolant since I bought it.
He filled it up and changed out my DCCV as my heater was running only hot or AC cold. Not sure if it was really the DCCV or just the fact it was so down on coolant.
After that it's been running fine and the heater AC works like it should except for this rubbing like noise after shutoff.
I think the cooling system needs more bleeding.
Anyone have a similar issue.
