Blacking out the Taillights..
Frasch
Nebrask-ha
A friend of mine does body work around the area - "PDR" work. He just went out and bought a 07 Chevy Suburban "loaded" White body color, anyways he just told me a guy at the local paint shop just blacked out his taillights. They look great on the white body color, im sure it would look even better with a black body color. Anyways I could get these done for maybe $10 a side maybe less, just seeing if anyone else had blacked out lights, or the do's and dont's about it! :cool:
There are a few different sprays you can use. The most popular is VHT Nightshades. It comes in a standard spray can size and cost about 20 bucks US. The second is to go to your local hobby store and buy model paint. They make a spray paint called "tint" or "translucent black." Its a smaller can, but only runs about 5 USD. Either one of these will do the job and do it well. You will only need one can either way. I prefer the model paint because the VHT leaves a blueish hue to the tint, and the model paint sets up smoother. The third option is an old hot rod trick. If you mix paint (any color) with clear coat, you create a paint that you see through. It was originally used for that DEEP paint job. You see the paint, but you see through the top three coats to the base coat. Its really sexy! Well the same stuff can be used on tail lights. Some part stores/paint stores can mix it up for you in either a pint that goes into a sprayer or in a spray can. The third way is the most professional but also the most expensive. For this write up I'm going to assume you are using one of the first two since they are the most common, but if you have the third style you should be able to use this as a guide.
Ok lets get started.
Things you'll need:
tint (your choice from above)
clear coat
Windex/rubbing alcohol
Lint free cloth or paper towel
latex or similar gloves
painters or masking tape
ratchet with 10mm (i think) socket
1000 grit wet sand paper
bucket with clean water
polishing compound
#2 Philips screw driver (to do the side markers)
heated workspace
First off, you need to remove the lights that are going to be tinted. I don't remember the exact tools needed, but its not hard at all. Open your trunk. on the inside of the light there should be 3 nuts/washers to remove. Once those are off, the light will move. You need to unplug the harness or remove the bulbs. This is all preference based on you. I did the harness. If you don't want to chance breaking the bulbs in the light, you can pull them out as well. Once they are free from the car and in your hands you should move inside. You want the temp of the lights and the space your working to be 65-105 F. Colder or hotter you will have issues with the paint adhering to the lights.
Prep work:
So here is where most people go and cut corners. I will say this process can be faster, but the results WILL show. Prep work is everything when you paint. Use the tape to mask off anything you don't want tinted. Maybe you want to do a stripe that stays red, or have a reverse light (non G5) that you don't want tinted. Get creative and make these lights your creation. You definitely want to mask off the outer edge and the backs to avoid over spray. Once you are taped off you can start the prep. First you need to make sure that you don't have any wax on your lights and the paint will stick without having a primer. To do that, take your 1000 grit sand paper and set it in the bucket of water. It should sit for a good 5-10 minutes. Once the paper is saturated, you want to lightly sand your tail lights. DO NOT move in a circular fashion. Either go side to side or up and down. If you make circle you will get focal points for the light and have to re-sand your lights and start over. Flush the lenses of the light with plenty of water while sanding and keep your strokes light. You want to sand everywhere that will be tinted. It should all look very uniform when done. You're light will seem a little hazy, and then when wet seem perfect. This will also fix any scratches you have in your tails. Now you need to put on your latex gloves. Take the Windex and clean everything off. It is very important to make sure the surface is clean. Alcohol and Windex will take off the oils from your skin as well, so make sure your bare hands don't touch anything after. Make sure the surface is dry. Alcohol and the ammonia in Windex make for pretty fast dry times anyway.
Paint work:
Now that the lights are prepared and ready to go, time to get ourselves ready. You can keep the gloves on or take em off. I'd recommend leaving them on to avoid touching the lights and getting paint on your hands. Set the lights on a bench/floor/table that is relatively level. You want to set them down in a fashion that will minimize running and allow free access to all angles of the lights. Generally speaking that means space them out a bit and face them up. Your spray paint is going to specify how to use it. its going to need to be shaken so lets start shaking. While your shaking, lets go over the painting itself. You need to keep the coats light. The tricky part is that you should keep the number of coats to 3. After three coats, the transparency starts to go down. VHT will mention this on the can, the model paint wont. So you need to use some judgment on how dark to make each coat so that after the third coat you are at your desired darkness. The first coat should be the lightest coat so the paint can get tacky and make a sort of primer for the following coats without running or streaking. The second coat can get heavier but don't over do it. The third coat is going on top of two sticky coats of itself. The running will be at a minimum so the coat be decently thick. Just make sure your second coat gets you far enough along to avoid having to over do the third coat. Make sure you spray evenly across the surface during each and every coat. Done shaking as per the paint cans directions? Good, lets do it then. Spray the first coat like I previously mentioned and let it dry for a good 15-30 minutes. After the paint gets tacky, you can spray your second coat keeping in mind that it can be thicker than the first, but the third coat is going to be the one that makes it dark. Let this one set for a solid 30 min. Now spray on your third and final coat. They should look like smoked tails now! We're not done, but they should look pretty good so far. Let them set for a couple hours. The can will tell you how long to set before working. After they are COMPLETELY dry.get your wet sand paper out and make sure its wet. You are going to lightly sand the paint now. Use the same method as before. This will eliminate any "orange peel" in the paint and help to correct any screw ups in the painting. The surface of the paint should look like dark glass not an orange with black marker on it. Once you get it all uniform again, wash it with the Windex again and let it dry off. Shake the crap out of your clear coat as per its directions. Clear coat painting isn't the same as the tint. You can spray lighter coats to avoid running sagging or streaking and you can spray as many as you want. I put down 4-5 coats on mine with total coverage in each. Let each coat set for 15-30 minutes before applying a new coat. Once your done with the last coat, let it sit for a couple hours again. The can is the guide on this again. The light will look bumpy and hazy when your done with the clear coat. Even after it dries completely it wont look right. But your painting is done.
Buffing the lights to a high gloss:
Once the clear coat has dried, you can buff the light out and make her sexy! This can be done by hand or by machine and a circular motion is preferred. If you do it bay machine, use a very low speed and less abrasive pad. It takes longer to do it by hand, but the control you have is much higher!!!! Only use a polishing compound... NOT a rubbing compound. Scratch X from Meguiars is a polishing compound. Either by hand or with a machine, buff until the gloss matches the one on your paint.
Don't look now, but your tail lights are smoked to the desired darkness and buffed to the right shine. You now have you're own little sexiness and it only cost you like 20-30 bucks! Install them on the car in the reverse manor of the removal and take pictures for immediate posting on here! Other lights beside the tail lights that can be done like this? All of them! just need to figure out if its a good idea and how to get them out. That's why I listed a Philips screw driver on the tools list. You need it to pull the side markers.
I'm sorry I don't have pics from the process.... but I did Sarah's on the G5 this past summer. If someone wants help with theirs or just wants me to do theirs..... I can take pics then. For now, here are some pics of lights I've done. I wish I had the G35 tails I did for a customer. Those were my magnum opus!
Before:
After:
[/quote]
Sully, GREAT write up...
One thing though... VHT Nite Shades is designed with a red tint to it, I've never seen it with a blue tint.
Also, a trick I used with my focus: It's a little more time consuming, but to have a Factory looking gloss on the outside, you can crack open the housings and spray the insides of them. This will tint it just the same, but allow you to mask it from the elements. Nite Shades says not to do this, because basically the Nite Shades won't hold up to the heat from certain lamps as well. I used the model paint that Sully mentioned (Testor's I think) with great results. Like I said, it's easier to paint the outside, but if you don't want to buff it to a shine every once and a while, crack em open!
IMO, tinting tails is a great look on most cars. On Black cars like mine, your's and Sully's, i don't like them to be BLACKED OUT, like Sully's are, I like to just tint them to a darker red hue. Sully, yours DO look great, but there's just too much black going on in the back for me.
PS: While you're doing the tails, do the side markers up front too ;)
My experience has been the blue tint.... maybe from the different batches? IDK. But the inside of the lights doesnt get as dark. I do really like the look of them like so, but its not as dark.
Sully or EM could you post a picture of you stepping on the brake pedal and maybe another picture of it in reverse so I can see how it will show up through it...??
can't wait to do this to my side markers as soon as it gets warm out!
maybe the tail-lights.... we'll see how i like the side markers
i just did the vht night shades 2 weeks ago and it looks great better than i was thinking. i did 2 coats so its not as dark as sully it just has a shade to it il post pics tommorow when its light out
just wanted to see how dark it was going to be just in case I had to get brighter bulbs in the back
I've been thinking about tinting my tail lights but not quiet sure how it'd look with my color, and how much will it cost, I'd rather not do it myself unless I seen pics with a walkthrough step by step.
I've been wanting to do this for quite a while now. Thanks a LOT for the write-up. That will be very helpful. I will likely do my reverse lights as well.
Has anyone tinted their headlights? I'm not saying anything like Sully's tails, just a little smoke. Or perhaps painted on the eyebrows with the tint then clear the whole thing..... hummm ideas.
there's a write-up right above! Maybe not with pics but.... perhaps this will help: http://www.corrado-club.ca/mods/tailtints.html
Also, Sully have you ever noticed that dude in front of the blue truck in your last pic? He is cooool!
I wouldnt spray tint your headlights. You could get in trouble for that and left with needing new headlights. I think the best route for smoking headlights slightly is getting some smoked Lamin-X tint. its made for headlights and/or fog lights.
thats a good write up yeah but my add prevents me from reading the whole thing
spsully ur ls is SICK, when u gonna show us those rings?
and thanx for the pics, knowing my noob ass i would need a pick of the paint can to know which one to buy. lol
thanks man.... but honestly, I can take credit for how my car looks in any of those pics. I have sold my wheels, I've bought and painted my LSE boddy kit, I have new wheels for the summer and stockers for the winter. HIDS, Angel eyes, stock subs, and a special surprise I have quite finished yet. By the time my car hits the road in summer mode, it wont look like the same LS. Thats why no pics of how she is now.
as for pics of the paints. I think I have one of each of the spray can methods. I'll check and get a pick on here.
here is my tails i didnt want them blacked out just a little darker
the can of vht i got it from summit racing about 17 dollars
sorry car is a little dirty because of the rain for three days
