01LSVT
So I'm going to install an HID kit this weekend. The kit I bought seems to have a higher demand for start-up wattage, because they don't do anything but flicker, and then shut off. So I bought a relay harness which normally hooks directly to the battery. In the case of the LS, I'm looking to tie straight into the distribution box. I'm no electrical guru, so I'm looking for advice. This harness has a connector, similar to the right end of what is pictured below. How can I tie this to the distribution box? Do I need to cut the connector off and wire/heat shrink directly into a wire coming off of the distribution box? Any advice would be very much appreciated.
Thanks!
Mark
Thanks!
Mark
