96 Conti is making "squuike" when up shifting ?
Justin5
HAMBURG, Germany
My 96 Continental is making a short "squuike" noise, but only when the Tranny shifts into the 3 Gear, after pushing with full thrust to the rpm limit out of the second gear on a freeway!
What can that be ?
Tranny-Filter and Oilchange is done with Mercon V maybe 500 miles ago. Conti has 65.000 miles on it .
Just the OIl may be 7 Liters what´s in the Pan, is changed by me,
i didn´t found a way to change the complete 13 Liter of Oil ( Theres also something left in the Converter ) ?
Greetz Justin
It's just your belt slipping a little between full throttle shifts. It's normal. Don't worry about. If you wanted to fix it, you will need to put a gatorback belt on it.
