Cutting oem-like springs should be fine. it won't ride stiff.. Stock like handling with stock-like ride, but lowered.
OEM springs don't have much tension, so .. if you're just cutting for one ring, it'll be no worries. It won't be too bad on Camber, and shocks.
On the other hand, if you where to cut Higher tension springs.. you're car will handle great, but going over slightest bumps will send your head bobbling... known to tuners as "rice bounce" lol.
it's all physics really.
I can't say for Marks, but i'm guessing buying 1.5 drop springs should improve handling, without killing your suspension ride.
I relate this from first hand experience but not from Marks. Back then, I wanted to lower my import. So I was going to put in ebay coilovers, but decided to go with cut springs.... best choice ever. Of course it handles stock-like, but the ride is comfy.. and the car has a nice stance. That's all i wanted, looks.
Anything dropped to 2" and below needs to be backed up with camber kits and performance shocks in the import world... or you comprise tire wear, shock wear, drive-ability and comfort.
Gl and let us know what happens!
