1996 MK VIII Memory switch
582Boat
Battle Creek, MI
I am having problems with the memory switch not holding the settings, it is not even showing any indication that it even works why?
So if you press "set" it does not light up green? Might just be a connection or maybe a fuse.
Memory switch
When I press "Set" I get no green light, and the # 6 15 amp fuse that controls the memory seats is good. Further :confused: information would be appreciated.
Have you replaced the fuse or tested it.. or just looked at it? Sometimes they melt in a weird area and they look ok.
But lets assume the fuse is good. Then you either have a memory module problem or a harness unplugged.
