My 1984 Mark VII LSC starter motor is continually running. I went out the other day and fired my car up and could not get the starter to disengage when it is in run position, I replaced the starter motor, starter solenoid and the ignition switch. The battery is brand new Autolite and the condition is the same. Have checked and verified that all the fusible links at the starter solenoid are good, and a visual inspection w/moving all of the wiring harness both under the hood and dash have no effect on it. One other item, my overhead cluster which has the lamp out warning lights, compass, outside temperature and garage door opener, lamp outs (3) are lit at all times and the headlamps, tailights and brake lamps are all working correctly. this began two days before the starter always running problem began and is present now. Could this lampout condition have then caused the starter issue. my car has been stuck at the Union 76 station for 6 days now because I don't want to ruin a second starter by trying to drive it home. Thanks for any help.
