towerpower
The title is just a portion of the problem...I'm in a parking lot and approach the car. I hit the 'unlock', nothing. No flashing lights, no sound of locks being released. I check...yep, my car. There's the coffee inside cooling down (15 degrees F). I hit 'lock' and 'unlock' again. Nothing. OK, I insert the key in the lock. It will not turn. NO--it's not a frozen door lock (see later). So I try the trunk release. Nothing. I try the key in the trunk..success. So, I'm in the lot looking around for a cop to explain that I'm going to crawl through the trunk of MY car to unlock the door. No cops, so I do it. I crawl to the front seat, open the door--the alarm goes off. So I start the car and the alarm quits. I go home, get the spare keys and fob. I try the key in the lock first..neither the regular nor the valet key will turn but the fob locks and unlocks the door. Then I try the keys again and THEY ALL WORK IN THE LOCK!! But the original fob still won't work. I go inside and swap batteries to see if it is a battery problem. Both batteries are OK but the original fob still won't work.
So, today...three days later...same thing except that it's the 'good' fob that won't unlock the doors. None of the keys work. So, I hit the 'lock' and get lights and a sound of door locks being activated. Hit unlock, it works. Keys work.
It's a 05LS with keyless entry. (entry codes weren't working originally, but I might have hit wrong entry code so don't take it as gospel).
Oh, the temperature is about 10 degrees F, but I don't think that is a factor.
