Navigation disk help
Adam Moore
knoxville
I just put in the Pioneer Avh5700Dvd Navigation unit in my car. Im need some navigation software to be able to use navigation and was wondering does it take a special kind of software or can i just get any kind of navigation software?
You need a navigation unit to be able to use navigation. What you have does not do navigation.
Description:
All-in-one design, no hide-away unit
6.5-inch Anti-Glare, wide-screen display
Fully motorised Touch Panel Display
DVD-Video, DVD-R/DVD-RW compatible
CD/CD-R/CD-RW/MP3/WMA CD playback
MOSFET 50 W x 4 Amplifier
D4Q Digital AM/FM tuner
iPod� adapter ready
General
Amplifier MOSFET 50W x 4
Equaliser EEQ+ Equaliser with HPF, LPF & SFEQ
Built-in AM/FM RDS Tuner D4Q
DVD Capabilities: DVD-Video/Video CD Playback with Direct Search, Chapter/Track, Next/Previous, Chapter/Track, Fast forward/reverse, Pause, Track/Chapter Repeat, Condition Memory (30 discs), Play back Control (Video CD only), Direct Search Title, Time Direct Search, Scan, Digital Direct
DVD Auto Play (Some discs may not fully operate on this system), DVD Bookmark Play, DVD eject Bookmark Play
CD Capabilities: CD Playback with Track Scan/Pause/Repeat, Random Play, CD Text, List Search, 96KHz/24-bit DAC
24-bit D/A converter
Track Search/Scan/Repeat
Track/Manual search
Last position memory (for CD function only)
Source Control MCD, TV DVD, DAB Tuner
Control via front panel buttons or Remote
Voice Guidance When connected to Pioneer Navigation System <-------
Wide TFT active matrix LCD colour display
Touch Panel Operation
Display size 6,5 Inch
Screen Coating High-quality AG (Anti-Glare)
Installation possibilities In-Dash
Fully motorised display with auto dimmer with free adjustable viewing angle (50�-110�)
Front panel Partially removable with safety warning beep
Selectable wide screen modes Just / Full / Cinema / Zoom / Normal
Rear camera switching
Remote Control - Optional
D/A Convertor 24-bit
DVD - R/RW and CD - R/RW Playback
Built-in MPEG 2/1 decoder
DVD video player
Region number 2
Connections
AV Output 1 RCA
AV inputs 2 RCA
AV Bus Input
Input for rear camera
RGB input for Navigation System <---------------
Optical Digital Output
IP Bus input/output
PAL/NTSC/SECAM compatible RGB input
Power Supply In
Rear monitor output
Description:
the system you bought DOES NOT HAVE NAVIGATION, it NAVI READY. you still have to buy the navi equiptment from pioneer, thats why it has the RGB input(the connector for the pioneer navi system) and it says voice guidance WHEN CONNECTED. the buttons are there to controll the navi if you get it. if it had navi, it would be a AVIC N series, last time i ordered the navi add on for a customer, it was about $800
Input usually means you have to buy additional equipment FYI.
Ahhh ok will i didn't know that. Thanks anyways for the help. If i was to get a new aftermarket NAvigation system what would be a good choice?
