Overheating problem
jtetpon
Kent
I have a 1994 Lincoln Mark Vlll. It overheats even tho the radiator, thermostat, heat sensor, most of the hoses, have been changed. What gives, anybody know? Thanks.
Yup. The system must be properly burped, its the reason most 4.6l appear to overheat. Direction right on hood or about.
Basically if your pouring coolant in the over-flow tank, well its wrong. You must always fill at the crossover tube. Top center front of engine. Fill, run engine (do NOT rev) and repeat until ALL air is out. I prefer to take it out for a drive when I cant get anymore air out in the driveway. I take it off-road to really shake any bubbles loose. Then repeat above again. Check in a week to be sure. That usually fixes it 99% of the time.
Burping the coolant is hugely important... put the time to make sure you have all the bubbles out before you hurt the motor.
Have fun burping..
I prefer to take it out for a drive when I cant get anymore air out in the driveway. I take it off-road to really shake any bubbles loose. Then repeat above again. .
Try this either park in a steep incline/driveway or jack up the front about 6 inches to a foot.
Find a plastic funnel that fits snug into the crossover tube.
( I got a short necked funnel from autozone that fits perfectly)
screw/press the funnel into the crossover tube and mantain 3-4 inches of coolant in the funnel.
run the motor with the heater on
by jacking the front up, you help move the air from the back to the front of the motor.
The funnel trick gives the air that would normally be swept back into the system and upwards route to escape because it's higher than the engine.
When I do it this way, I usually get the car fully filled on the first try and rarely have to add more than a glassfull of water later.
give it a shot it works really well.
it works really well...
the funnel I used had about a 2-3 inch short fat neck and was about 7-8 inches in diameter at the top
this might even be the same one.. but this is what you are looking for
I tried that method on the Mark I had with blown head gaskets... it shot coolant out of the funnel the entire time... it was pretty fun to watch lol...
