check advance traction
BAD_LS
Atlanta
i got a 2002 lincoln ls and sometimes when i push the brakes i traction control light on the dash pops up and it said check advance traction what does that mean ?
it might be your sensor for the abs, it means your traction control and abs isn't working. You will probaly get a better anwser but i would suggest cleaning the sensor.
If the ABS waring light is not on, then the ABS is still working okay. The Advancetrac has sensors beyond those required for the ABS. It likely that one of those sensors (such as steering angle or one of the accelerometers) has a problem.
