Muffler Bearings
You get them at the same place you buy your blinker fluid, direct exhaust injection kits, and Mr. Fusions to power your flux capacitor.
Why are you asking such a stupid question anyway....use the search function next time newb.
level bubbles... they are hard to find.
has one one done a rite up on installing new level bubbles?
If you have been thru Joplin, MO then you would have seen the F.A.G. Bearing plant, where they are made. It is right next to the inter state and alot of people just stop to get their picture taken standing next to the sign.
No way thats old skool technology, havent you heard of the new levi-tron muffler bearings? they have 0 rolling resistance, so they rob 0 hp to rotate ;)
You obviously don't know much. Timken has teflon-coated platinum bearings that require no grease!
:D
We sent a guy out to get some @ Kar Parts along with some Plugs and Points for a 6.2 diesel. Where still waiting for him to come back :shifty:
Well Frogman, you owe me big for this one. Although Elmira is a small town in upstate NY I did the following. I spent all last night doing a recon with my Generation 2 night vision glasses all over town (not having access to the newer generation military glasses ). This of course took much longer as I was using outdated equipment. I then found a spider hole to stay in until daylight. Next I put on my best camouflage to blend in with the locals. After an exhaustive day trying to master the local language ( my N.S.A. language courses paid off ) I finally located those blasted Muffler Bearings. Only one problem, they only had them in red! I got the last two cases for you. It cost me my favorite camel plus 3 American Laws ( I secretly set those to explode the first time they are fired ), lol. I have a military drone on loan from the Air Force to record that calamity. Anyway PM me, make sure you use only the Morse code (security being the top priority ). I will have them shipped anywhere in the sandbox you want. Local deliveries are a little extra ( inflation, economy and all). This message is set not to self destruct in two minutes. Your friend, Gary in Elmira NY.
summits got a great price on some high performance muffler bearings....they even come with some summit bucks..............they do require taping into your oil pan for proper luberaction for them.
:D
2 NIB OEM muffler bearings
They are the purple ones. Part #'s F70Z-OICU812-AA (drivers) and the near impossible to re-place, F70Z-OICU812-AB (passenger). The AB is the updated 2nd gen design that were re-engineered to take advantage of the new style krypton roller needle rocker bearing. I also have the special FOMCO tool to replace said bearings, but it's a left hander. KY-Jelly for lube and install is optional, but also OEM. The KY K-Mart sells will work, but requires a modified square round nipple head.
I was going to use them on my Craftsman 16hp riding mower for race season 2009. The sanctioning body informed me they were illegal for my class so I have no further need for them.
Make offer.
kaleco is the only place to get them, but they don't have a phone, that old tech. you have to tex-message them or send them your thoughts. if that doesn't work, a string and 2 dixie cups always is a failproof to get ahold of them.
Hey after you get those bearing can u grab me some fluid for my rear view mirror it low. ohh!!!! and some bulbs for my front tail lights.
Will these muffler bearings fit to my "O" Pipe? I'm having a hard time connecting it to my exhaust.
After that's installed, I need to put in my cross drilled brake lines. :D
ive heard that dual O pipes have less drone.....
I have some rare diamond studded knibbler pins that link the throttle body to the sunroof so you get more air flow if anyone is interested. They would really allow those bearings to spin with an antigraviton effect creating a jillion jigawatts and eliminate the drone completely.
