1998 lincoln mark viii engine parts
topher5150
Grand Rapids, Michigan
I NEED TO GET RID OF THIS FAST 130,000 MILES
If your interested please PM me with a decent offer and we can figure something out if you need a pic let me know
left cylinder head
right cylinder head
left and right valve covers and coil covers
8 coil packs
2 intake manifolds upper and lower
fuel rail
8 fuel injectors
2 throttle bodies with throttle position sensors
left exhaust manifold with O2 sensor
right exhaust manifold with O2 sensor
fly wheel
crank shaft
EGR tube
2 EGR
cooling tubes (tubes which run under the intake to back of cylinder head)
2 crank and water pump pullies sold as a set
pair of motor mounts
timing chain tensioners
idle air control
oil pick up tube
oil pan
power steering resivor bracket
complete fuel injection wiring harness
water pump
emission tube and valve and bracket (the one that runs in front of the engine to the cats)
timing chain cover
IMRC left and right with seals
IMRC motor, cables and bracket
oil filter bracket with oil pressure sensor
coolant crossover tube
air filter box with K&N air filter
MAF housing
i want the coolant crossover tube if its in decent shape..
Pm me with a price shipped to 60173(chicago)
left cylinder head
right cylinder head
8 coil packs
fuel rail
8 fuel injectors
fly wheel
crank shaft
EGR tube
2 EGR
idle air control
oil pick up tube
oil pan
water pump
timing chain cover
MAF housing
PM me price of valve covers and coil covers to 08088
i never got a response back? but i dont need the crossover tube anymore though. found a different one for sale.
sold the valve covers and coil covers, and one of the throttle bodies.
i still have every thing on the list to sell including another throttle body
