touchy throttle response
fiddler
malvern, ark.
have an 05 v/6LS that has what i consider to be verrrry touchy/overly sensitive throttle resp. when cruising any application of the gas pedal results in too much. the cruise control even reflects this problem (slight surging, isnt steady). when leaving a stop sign you give it gas, little happens, give it some some more and here you go. very aggravating. what could be the problem?
Maybe you were driving a slow-ass 4 banger before the LS?
Seriously though, when I first started driving the LS, I thought it was on the touchy side too. You'll adapt quickly.
throttle by wire, my 1st gen didn't seem to have this problem. now that i am used to it i like it, get in the gas and GO.
throttle response
hopefully you are right. thought there might be some kind of adjustment or something........by the way my other car is an 87 grand national buick
Not sure on the V6, but my drive by wire throttle was replaced under warranty for a similar intermittent problem on my V8. On mine, the throttle would respond with too much throttle when starting from a stop and when you backed off the engine would die. It was very frustrating as it would only die intermittently and left no fault codes for over two years. When it finally left a code, the code did not really give a direct clue. Fortunately for me the mechanic at my dealer had read or heard that the problem was related to the throttle body.
WOT from a dead stop, I think the throttle response sux in the LS. But its because of the throttle by wire (or as I've heard it by "Fly By Wire") set up. I never did like that idea.
Having custom tunes makes a BIG difference with fly by wire throttle on th 2nd gen LS.
+1 on that. Even getting the dealer to flash a later factory tune will make a big difference. I use Torrie's tunes on my 04 LSE, but over the past four years, I did have a newer factory tune flashed to my car and it made a huge difference. Almost as must as the custom tunes made when compared to the old stock tunes. BTW the drawback to having a new factory flash is that all you custom tunes have to be redone.:)
How would I go about having the dealer to flash a later factory tune? And cost?
Depends entirely on you dealer. Also on your warranty status, Under warranty it is free. My dealer always checked for newer flashes when ever my car was in for service. In most cases the new flash addressed things that did not impact my car so we did not use them. Sometime in 2005 IIRC, a new flash became available that addressed enough issues the we decided to use it. It addressed transmission issues along with a list of driveability issues that upgraded the UNG0 coded program that came on my 04 LSE.
