Which rim?
unity
Green Bay
The Exodus is not longer made in the 5X108 pattern, so I may have to look for something else.
These three looked good to me. What ya think? These all have a 40mm offset.
18 by 7.5"
18 by 7.5 inch
18 by 8 inch
And how would 20" rims do in 7.5" with 40mm offset?
Would they fit without rubbing?
Wich one is the exodus?
vvvv for wheel fitment.
http://www.bigcustomwheels.com/rt_specs.jsp
I have 19x8.5 with a 47 offset and 225/35/19 tires. That site says it should be ok on most vehicles. However even though it was only 3 mm wider im going to have to use a 3mm spacer. The wheels contact both the brake bracket and the metal thing that connects to the uca.
if you get 225/40/20 you will be oem spec minus you'll fill out the fender another 6mm. Not a big deal.
This is the Exodus:
wheelsmarket_2002_25094890
I spoke with JK and they have it in a 20" by 8.5" with 40mm.
This is the Exodus:
no no no. Some black rims look good but most dont.imho
That said. When talking fitment its all about the tire size once you have the right offset.
I'll go with the chrome 5 spoke. Simple with alot of bling. Add some 235/45/18's and your set.
So an 8.5" wide with 40mm will be okay though?
with a 225 tire.
CORRECTION: I said earlier that mine were 3 mm closer. I meant to say .3" closer, 11 mm. Glad i didnt order my spacers yet, i even had my self fooled.
Well 20 by 8.5" in black have been ordered. $90 each since they could not complete my 18" order.
We will see how they look. I think on the Opal Mark they will look good, but if not its nothing to re-paint then silver or something.
I am not a fan of chrome, its everywhere now.
