JWerner2
- Joined
- Mar 27, 2008
- Messages
- 4,935
- Reaction score
- 2
I thought red was the only color that must have a reflector of the same color. From what I have just read a few days ago as long as a amber bulb is present you could use a clear reflector.
They consider all red bulbs to date to not be bright enough. If anyone ever comes out with red bulbs that give out the appropriate amount of light they then could be used under a clear reflector.
BUT, if the car has side markers in general they must be present. Most cops don't know the difference and wont hold it to you if you decide to get rid of it all together and fill it in. I cant see it as something they would just sit around and look for but they might bring it up if they get you over for something else.
FYI ( cause I know this will come up sooner or later ) the DOT does not approve anything nore do they have that right. They only set standards in which these companies must comply with.
