wheel bearing replacement
Jeffguy11
Wethersfield
Could anyone tell the procedure for replacing front wheel bearings? Or should i just bring it in and have it done. It's on my list of things to do but ive never tackled wheelbearings. Any help would be appreciated!
The wheel bearings are packaged with the hub. Both front and rear. Just remove the nut and hub, then install the new hub, with a new nut and torque to spec. You can replace the bearings if you want to press them out, but its just better to get a new hub assembly.
Once you do one side, the other side will take less than 20 minutes.
The tuff part if getting the brake caliper off. They may be stuck on pretty good. Try tightening the bolt a little if they do not back off. Once the caliper is off you just slide off the rotor, remove the dust cap and get that big nut and torque wrench on it. You can "rent" the nut from most part stores now.
I can do each in under 8 minutes now. Pretty easy job. Once you do it you will be glad you saved the labor.
Oh, and have a nice wood block to lay the caliper on. You do not want it hanging from the line.
I re-used mine. They are hard to come by, NAPA does sell them though.
thanks so much for the info- i think this will go easily since i just did all new rotors/ calipurs/ pads therefore it should all come apart easily. Should i go to ford for the part or are aftermarket replacements the same deal. I always go with ford parts but ive heard that with bearings theyre mostly the same thing no matter what brand.
No. Careful with these. OEM are best. Price around. I have a brand that I had to replace TWICE already. That 4 bad sets, now I have a brand thats holding up just fine. I forget, but I *think* NPT was the "bad" brand.
oem bearings are "timkin" (at least thats how i think its spelled) just make sure the new bearings say that and your good
The O/E parts are ....F6SZ-1104-BA for the hub and F3LY-3B477-A for the nut and LVC cost is $74.87 for the hub and $10.37 for the retaining nut, plus frt
Max
Max
I think thats what I paid for off the shelf at Advance. Heck, if you can get Ford OEM for that I would. Next time I will.
