No Sat
LEOV5
So Cal
That is what my radio display says. I have PIE adapter installed for over a year and it has been working great. Friday it started to read show NO SAT now the Ipod will not play thru the radio. It will still charge it but not play. As anyone had this problem and wht is the fix? HELP!!! 05 LS with the 6 disc with the SAT button next ot the AM/FM button.
i have seen this problem before with both pie and pac units. try unpluging it for a minute, then plug it back in to reset it, see if that works. if it has dip switches on it make sure they are set right. if you have updated your Ipod recently you may need to go back to an earlier firmware, a large amount of non apple aftermarket products will not work with new Ipods or Ipods with current firmware due to changes apple has made.
