LikeNew02
Hi Guys,
My car is overheating and I am pretty sure that I have a stuck thermostat. Can you guys answer a couple questions about replacing the thermostat.
Does anybody have replacement instructions that they can upload?
How long does the job take?
I found these instructions online but I was hoping for some my details and pictures. "If you have a V8 you must first take the cover off of the motor. Then with a 5/16 socket take the entire ac tubing off starting from the intake on the upper left hand corner of the motor. Then right up under the container labeled torque remove the screws with the 5/16 socket and a 3/4 extension be careful not to stripp the screws. If water start to drain a little thats okay. You should hear a little air escape due to the pressure coming off of the thermostat."
thanks in advance.
thanks in advance.
