ughhhhhh
There is also a kit you can "rent" from Autozone and such, its for O2 sensors. Probably works well like the crows foot set. But its designed with those wires in mind. Basically a socket with a side cut out of it.
they had two different 02 sensors listed for my gen 1 95 base, one has a longer pigtail the other does not? i went with the shorter.
I went to Autozone and picked up the tool ... 21 and some change - plus i can take it back and get my money back, picked up a can of PB blaster and Liquid Wrench.
jacked the car up, jack stands of course tried getting my beastly hands to manuever the tool on the passenger side 02 sensor, i can just barely get it on there but not enough leverage to turn it.
so i called gene at lms to ask what in the world do i have to do? cuz at this point im lost.
he told me you have to drop the exhaust down - this is where i ran into problems and feared the rain and didnt want to go any further - also i thoght it was time to find someone with a lift, air tools and a blow torch - because this wasn't something that I was going to be able to do with hand tools, beer and a couple swear words....
I pb'd and liquid wrenched - wrapped with a hammer the passenger side exhaust flange that connects to the cat - its two 14 or 15 mm bolts (if someone could verify ide appreciate it) i know the one you cant even get to because the 02 is really in the way, gene said to use a universal, im guessing he ment wrench? or vice grips? for the end of the bolt, not to sure? man those things wouln't bug to save it's life - another tip he told me was to start the car and have it get real hot to be able to take those bolts off, ehh thats when i realized i wasn't equipped to do this job at the present time.
had everything not been all rusty on those cats and pipes, i would have been in the clear, dropped the exhaust no problem - but they look so terrible I called it quits right there so i can still drive it.
ok the pipe that connects the third cat to the two cats ( i guess this is what you guys call a Y pipe?) the driver side had bolts that looks i could seperate the Y pipe from the Cat, but the other side looks like it has some kinda weld on there holding it together
im not sure if this is what you take a part to get the cats to drop down to access the 02 sensors? or if he was talking about the two bolted flange that connects the exhaust manifold to the cats....
ive searched pretty heavy, i guess if you see rust on this stuff, dont even bother doing it because i gurantee you this is not a job that is easy by any means... I guess if you dont live up north this is a cake walk, but as for me the exhaust manifold and exhaust is a big pain in the ass in trying to get your hands on that 02 sensors
