low coolant
DSPENCER
ORLANDO
Hey all, my Low coolant warning keeps popping on occasionally when im driving for like 10 min then will go away, I checked my water and its topped off, any suggestions what this might be?
If it is the in tank sensor then you have to get the complete coolant overflow tank and sensor assy. P/N F3LY-8A080-A listing for $79.92 and LVC cost $57.54 plus frt.
Max Zuckerberg
Parts Specialist
Five Star Ford
7100 east Mc Dowell Road
Scottsdale AZ 85257
Direct 1-800-866-1520 ext 236
Fax 1-480-949-8478
parts@fivestarford.com
Max Zuckerberg
Parts Specialist
Five Star Ford
Scottsdale AZ 85257
Fax 1-480-949-8478
my car does this too but only when its ICEY cold out. Can't you just replace the sensor?
I fixed my light by adding some coolant. Thought it was topped also, but had some room on top.
You get a free sensor with every tank....Seriously the sensor is not available as a separate part.
Max
ohh geez I wish you would have had this problem earlier.....it took me a little more than 4 months of getting tired of pushing the Reset switch every time It beeped....then I got mad a gave the ("MarkHate" only when it is bad:mad: ) it's precious coolant it was only like 1/8 cup in the reservoir:shifty: , but was just enough!...go figure
Bahh Inferior Message Center mind you my "oil life" has been at 99% for over 3 years like WTF??:confused:
There might be air trapped inside the cooling system, try bleeding the system by open the fill cap on the cross over tube and run the engine for a min or two. Not to long. All you want to do is to cycle the coolant a few times through the block.
